Hiding away AV equipment
Discussion in 'Cables & Switches' started by celtic1967, Aug 14, 2013.
  1. celtic1967
    celtic1967
    Oct 17, 2005
    1,117
    Luton
    +38
    I have Sky HD box, Wii, Xbox 360 and a Samsung 2.1 home cinema in my family room and its a mess of wires feeding directly to my Panasonic plasma tv.
    I would like to put all the AV equipment discretely away from the tv (maybe in a corner) a distance from the tv for neatness.
    Any ideas on what would be the best way to do this bearing in mind that the Wii connection is via scart adaptor and need to connect wii sensor bar and Kinect sensor to the consoles and position them around the screen ?
  2. tvmcp
    tvmcp
    Oct 2, 2009
    1,236
    Basingstoke
    +220
    Not sure if it helps, but you can get wireless wii sensor bars.
    I've had 2 in the past, one was very good, the other really poor, using a wired one now, so can't actually recommend one of the top of my head.
  3. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Do they all have seperate cables to the TV or do they all connect to the Home Cinema and then onto the tv ?
  4. celtic1967
    celtic1967
    Oct 17, 2005
    1,117
    Luton
    +38
    Currently the sky box and x box are connected to the two hdmi inputs on the Samsung e5200 and the hdmi out goes to the tv.
    The added complication now is the Wii which is scart only.
  5. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    You could convert Scart to HDMI but as the samsung only has 2 HDMI inputs this would really help.
    You probably need to google Kinnect and Wii Sensor bar extenders
  6. celtic1967
    celtic1967
    Oct 17, 2005
    1,117
    Luton
    +38
    I think that my set up doesn't lend itself to a "clean" install:rolleyes:
  7. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    You could add a HDMI Switch and Scart to HDMi Convertor but seems over the top for teh sake of one cable
  8. celtic1967
    celtic1967
    Oct 17, 2005
    1,117
    Luton
    +38
    Absolutely
  9. celtic1967
    celtic1967
    Oct 17, 2005
    1,117
    Luton
    +38
    There is a Wii2hdmi gadget for around £15, think I may give that a go for starters
  10. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Not seen those before, interesting.
    Still leaves you with the problem of extending Sensors though.
  11. celtic1967
    celtic1967
    Oct 17, 2005
    1,117
    Luton
    +38
    Yep, or sell the consoles on ebay while the kids are at school !!!!:D
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,519
    The Borders
    +3,470
  13. celtic1967
    celtic1967
    Oct 17, 2005
    1,117
    Luton
    +38
  14. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,519
    The Borders
    +3,470
    Yes - you will also need the Wii 'Component' cable!
    Joe
