HiDef Pack for xbox and Projector Use
Discussion in 'Projectors, Screens & Video Processors' started by windfall, Aug 30, 2004.
  1. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Hi Guys
    I finally plugged my Hi Def Pack into my xbox yesterday and was not please with the results!
    I get a fine set of lines about every 10 pixels accross going from top to bottom of the picture on my PTAE100.
    My Xbox is plugged into the amp which in turn sends the pic to the PJ. I have been through the menus on the xbox (executer 2.2 chip) and cannot see anything that mentiones out put.
    When using component out is there anything else I should do with the xbox?
    My DVD also connect to the other set of component inputs that has no such artifact on screen.
    Any help would be greatly appreciated.
    Tone
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Tone,
    I know what an Xbox looks like and that's about as far as it goes......... Have you checked over on the consoles forum, someone may have had similar issues ?
    Sean G.
  3. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Will post there, thanks mate.
    Tone
  4. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    You need to run the NTSC EEPROM and enable 480p/720p/1080i through the msdash, have you done that?
  5. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    I have resolved the issue, it was that none of the settings in the MS Dash were set to progressive. Now I have enabled all of the (480p 720p and 1080i) the picture is great.
    Does anyone happen to know if the 720p would be useable by my PTAE100?
    Thanks again for the help.
    Tone
  6. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    Even 1080i is useable - the AE100 says it's receiving a HDTV image, forgot the exact signal name (like wide480)
  7. phfjones
    phfjones
    Mar 22, 2004
    99
    Tonetrainer,
    If I am not breaking forum rules, did you use a UK Xbox or a US import. If so where did you get it?
    Just bought a Digital Projection iVision 720res, and looking to use HD on Xbox also.
    Paul
  8. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Don't want to be a kill-joy here guys, but please check over on the consoles forum to see whether discussion of "modifed" xboxes etc. is allowed on the forums............. Don't want needless thread closure for want of keeping within the rules of the forum.
    S.
