Hidden Sky dish ?
Discussion in 'Sky Digital TV Forum' started by RichB14, Nov 29, 2003.
  1. RichB14
    RichB14
    Nov 8, 2002
    764
    Surrey
    +18
    Well I'm moving in December and the property we're buying has restrictions on where you can have a Sky dish installed, we can't have it anywhere on the front of the property but we can on the back. So my dilema is if the signal requieres a dish on the front what can I do.
    Is there anyway of having a dish in the loft or anyother options.
  2. darren7
    darren7
  3. wod
    wod
    Sep 7, 2003
    196
    +3
    have the dish fitted on a pole at the back , so the dish can look over the roof ?
  4. RichB14
    RichB14
    Nov 8, 2002
    764
    Surrey
    +18
    Looking at the cost of the other options I think I will have to go for the pole option mounted on the back of the house.
  5. rats
    rats
    I couldn`t have a dish fixed to my property, the ideal location was at the front, which was a no-no, so I fixed a pole into the ground at the rear, in the garden. The dish is no more than 4 feet from the ground. Picture and signal are fine.
  6. RichB14
    RichB14
    Nov 8, 2002
    764
    Surrey
    +18
    Does anyone know where the astra satelite is positioned, is it easterly say ?
  7. wod
    wod
    Sep 7, 2003
    196
    +3
    28.2 degrees east of south
  8. RichB14
    RichB14
    Nov 8, 2002
    764
    Surrey
    +18
    Looks like i might be able to mount a dish on the rear of the house set at a right angle to the house and that should give me the south east angle.
    So now to Sky+ or not...........
