hidden install freeview box?
Discussion in 'Freeview & YouView' started by Beneteau121, Jan 10, 2012.
  1. Beneteau121
    Beneteau121
    Jan 10, 2012
    2
    I have a friend with a TV in the bathroom all flushmounted can any one tell me If there is a remote mounted freeview box which could be mounted in the cupboard of her flat which uses a magic eye system to operrate the remote controls as the freeview box can't be mounted in the bathroom and the only cables at the back of the TV are the ariel and the power
  2. digibobwigan
    digibobwigan
    Jan 9, 2012
    wigan
    you are talking about a tile tv and the early ones didnt have freeveiw they are made not far from me at bolton if you contact the maker of tv you can get an upgrade kit for the tv and thus make it freeveiw
  3. Beneteau121
    Beneteau121
    Jan 10, 2012
    2
    She sent it back to the manufacturer as she thought it had gone wrong when the area switched over to digital and it stopped working they can't upgrade it
  4. Rodders53
    Rodders53
    Dec 8, 2007
    4,905
    Bedford
    +863
    There are some Freeview boxes with a 'RF modulator' that you can find, albeit rarely and you would require some form of 'infra red extender' for control.
    The Triax Tri-Link (download the user manual) may be suitable for any receiver with a bit of faffing around (for the magic eye bit) in the bathroom? Depending on how the aerial cable distribution is routed they may be able to connect it to their existing equipment (e.g. a PVR in the lounge) rather than an extra receiver?
  5. iaint
    iaint
    Jul 4, 2011
    640
    28
    +89
    Hi.
    Not cheap, but see if you can find the A2B Multibox 6T; multibox6t.co.uk - one box, six channels. Imagine a stack of 6 Freeview receivers in a stack, tuned to different channels, outputting as 6 different analogue channels... Use existing TV remote/controls to change channel, but only between the 6 configured...
    Regards, Iain.
  6. earth2ohm
    earth2ohm
    Feb 5, 2012
    Jersey
    trouble is, going with a freeview box remotely controlled in the bathroom, how long will the actual remote last? there are loads of ways to be able to control it in the bathroom, but i would say for all the trouble its worth and then once its fitted the control gets dropped in the bubbles, maybe its time for a new wet room tv with freeview built in.
