Hi8 to Mini DV Tape
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by russ hirst, Jul 1, 2005.
  1. russ hirst
    russ hirst
    Jun 18, 2005
    30
    11
    Harrogate, N Yorkshire
    I have been copying my old Hi8 tapes from an analogue camera to my Mini DV camera and notice that after the copying has been done, on playback on my PC, at the very bottom of the picture, there is a line across the picture. Most people probably wouldn't notice this but it annoys me!!
    Is this just a consequence of analogue to digital or is there something I haven't set/done/checked?
    As usual, comments would be greatly appreciated.
    Russ
  2. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    This is due to the overscan on PC monitor showing more than a TV does.
    All my video footage produces a 'line/rollover' of some kind at the bottom on my PC.
    Also it depends on what software you use. Power DVD tends to show more than others.
    I wouldn't worry about it, it won't show up on your TV (or shouldn't do!)
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    The chances are that the noise line is in the overscan area of the picture. This overscan area is visible on a PC, but is not seen on a properly setup TV screen. Try playing one of the DV tapes directly onto your TV and see if the noise line can be seen - if not then there is nothing to worry about.
    Mark.
  4. Roy Mallard
    Roy Mallard
    if it's that big a deal you can zoom slightly into the imagw, meaning no lines on playback, however you will get a slightly softer image and will require afair bit of rendering.
  5. russ hirst
    russ hirst
    Jun 18, 2005
    30
    11
    Thanks guys. As usual your prognosis is spot on!!
    Russ
