Hi Rasczak
Discussion in 'Blu-ray & DVD Players & Recorders' started by General Panic, Aug 25, 2003.
  1. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Hi again Rasczak :hiya:
    A quick question if i my regards your Panasonic PC recorder. Do you use/recomend any particular -RW media?
    I've got RAM and -R disks ok but only just realised the drive i've just ordered uses -RW as well and that should be cheaper than useing the RAM disks i was going to use.
    TIA
    Panic
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,281
    I have been using JVC DVD-RWs - they were readily available at a local store so I snapped up a 5 pack. No problems with them at all. I'm sure some of the Sony GX7 or Pioneer DVDR7000 users will be able to suggest some decent disks.
  3. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    I have used Princo RW 1 speed media a lot and no problems.
    These were going for 90p each (a bought a few!), but seem to have vanished now.
    You can get 1-2x rated (Princo branded) for £1.35 each from http://www.lynxdv.co.uk/product.php?name=princorw
    Alternatively you can get DataSafe branded 1x (Princo made) DVD-RW for 0.89p from www.blankdiscshop.co.uk.
    If you are only needing a couple of discs for testing purposes (i.e. test an author to DVD-RW before burning to DVD-R) I would suggest spending a bit more for some good branded media. Either way test them out before going for a bulk order if you want a lot.
    For data use, while DVD-RW will do the job, you are better off with DVD-RAM.
    Regards
    Philip
  4. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Thanks for the advice guys :)
    Panic
