Hi, help me get video from camcorder to pc!
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by plastique, Jun 28, 2003.
  1. plastique
    plastique
    i've got a few things filmed and i would like to get them from the camcorder onto my pc to be edited. only trouble is the camcorder doesn't have a firewire connection, just composite video out!
    Help!!!
  2. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    You will need to get a capture card for your PC.
    These are not that expensive and can be bought from the usual PC component places.
    Watch out though as you will use LOTS of HDD space.
  3. plastique
    plastique
    Thanks, I'll have a look!
