Hi FI Wall Shelves
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Mitch2000, Jan 27, 2004.
  1. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Has anyone come across some wall shelves for standard size Hifi Kit? I'm interested in two shelves, one for an amp and one for a CD player. Glass or wood preferable.
  2. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
  3. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Just the sort of thing I'm after but they cost more than the equipment I've just bought.
    Anything similar available?
  4. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    I'm thinking right now of my bathroom suite which has a glass shelf near the bathroom - bought at B&Q. Perhaps a visit to the bathroom section there and a subsequent trip to a glazier to modify what you see/buy would be the answer.
    There is a danger, though, that any such modified item may not be sturdy enough to hold the weight of your equipment. I can't think of anything else.
    Let me know what you do eventually
  5. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    MMM... Not to sure about shelves anymore. Did think about a couple of those metal things they make for Poratble TV's but its got to look good as well. Maybe I will look for a stand instead. I just don't want to keep bending down low and fiddling about with CD's, I want everyting at a decent height.
  6. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Ikea do CD shelves that you can hang up on the walls horizontally. If you have one nearby it might be worth a visit.
  7. bobbypunk
    bobbypunk
    vogels do a system where you have no shelf just a v-shaped metal prong. Can be used like that or source some glass seperately.
    www.vogels.com
    and look in the consumer section.
  8. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    Thanks. Vogels stuff looks like good stuff and at a reasonable price.
  9. bobbypunk
    bobbypunk
    yeah the rep was showing me some of their newer stuff and hanging a plasma from the ceiling does look good!!
  10. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    I thought you couldn't hang a plasma from the ceiling as the glass warps because it gets so hot and the screen cracks?
  11. bobbypunk
    bobbypunk
    Hangs down on a pole and stays at normal height as if it were wall hung. Hangs from joist i think!
