Hi Fi Rack - Space above amp
Discussion in 'AV Receivers & Amplifiers' started by Jon, May 26, 2004.
  1. Jon
    Jon
    How much of a gap (from top of amp to shelf above) would you say would be the minimum space required for an AV amp. I have the Pioneer Ax5i (not that this should make any difference)?
    Jon
  2. BKATZ
    BKATZ
    Aug 4, 2003
    164
    Jon,
    I am sure you have seen Pioneer's recommendation (on page 2)[60cm above, 10cm rear & 30 cm either side] I hope they meant mm & not cm!!!
    Anyway, IMHO an inch top & sides should be OK, just make sure you have plenty of space at the rear where the fan is.
    Regards,
    B.
  3. Jon
    Jon
    cheers mate! I did see that and thought the same thing, Thanks for your reply!
    jon
  4. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    Jon, click on the link in my signature and you can see exactly how much space there is around my AX5i.
    It does get warm on the top (as does the underside of the unit) but nothing to worry about.
  5. Jon
    Jon
    Thanks Brogan!
  6. BKATZ
    BKATZ
    Aug 4, 2003
    164
    Quick pick of mine.So you can see "the gap"
    [​IMG]
    B. :)
  7. Jon
    Jon
    Cheers Mate!!!
