Quantcast
Hi Fi in storage
T
TagBeijing
My hi fi has been professionally stored in a warehouse (in Manila) for the last eighteen months or so. Speakers are Snells (E5 fronts, CR5 centre and SR5 rears); clever boxes are DVD32R, AV32R processor and 100x5 power amp.
Any suggestions or advice about re-setting up after such a long period of time in storage ?
The TAGs were all bought in Singapore and I now hear that the local TAG store has closed down, does anybody know if IAG/TAG has presence in China/HK as i would like to consider updates such as progressive scan etc.
Finally, after eighteen months away from my babies I have forgotten the regional coding hack via the remote - can anybody remind me. Thanks.
Teejoo
regarding the setting up: just let the stuff get the same temp as your room temp, to avoid moisture. In other words, set it up, but don't turn it on for a few hours.
If you performed the regioncode change once and set it to 0, then you won't have to do it again as long as you didn't do a master reset.
T
TagBeijing
Thanks for the info with regards to resetting up the kit.
For the region coding I used to change the setting depending on the region of the DVD. There was a code that you enter via the remote each time you use a DVD from a new region. With the kit in storage so long I have forgotten the code - the guy in the Singapore TAG showroom told me but that has closed down now.
So can anyone recall the code ?
Also, the DVD player top loadinglid never worked properly and I had to manually slide the top back and forth to open/close. Anybody else ever have this issue ?
Teejoo
The DVD32R's door has been modified and optimised the first few years. However I don't believe there has been any change since 2 years or so. If your unit has the latest version, you can switch between 2 door profiles: A=fast, for older models and B is slower, for latest version. So, how old is your unit?
(I've sent you PM regarding the region code.)
mlinhares
Here it is:
codefree sequence:
1. no disk in the player
2. close the tray if it's open
3. key in 734* (where *is the region)
Notice for memorization that 734 in the keypad is reg(ion), i. e., 7 is R, 3 is E and 4 is G.
I believe that 0 in the region will read all regions.
Have fun.
Stereo Steve
Your speakers will probably sound naff for a day or two. I stored my Ruark Preludes and the cones must have got a touch damp as they sounded appalling after I got them out. Took a week to come back. Just thought I'd mention it so you don't panic as I did.
T
TagBeijing
Thanks for the info guys. Just got back from four days in Inner Mongolia hence the lack of response fom my end.
Have fun.
P
Peter
Radar Audio in Hong Kong are TMA distributors. Tel +852 2576 0021 for the showroom in Causeway Bay, ask for Patrick (the others are clueless).
K
kallenby
Hi Guys,
Just to clarify on the statement that the local TMC dealer in Singapore has closed down - no he hasn't. He moved from Liat Towers into the basement of the Specialist Shopping Centre by Somerset MRT - about 1 year ago.
David is very much alive and well & still dealing in TMC stuffalthough his 'new' shop is much lower status than his original one,
Cheers,
Similar threads
