hi-def question about bit rates
dapex
hust got 5th element which it says is HD, according to media player it is playing at about 4805 KBPS variable bit rate, does this sound right for Hi-def stuff??
Steve.J.Davies
I have identical footage mastered in
SD
HD with h.264
HD uncompressed
will run some tests and see what bitrates I get.
just gotta find the stuff...
Steve.J.Davies
Found the stuff and pointed Media INfo at the folder. No info back re the native HD stream.....bot got output for the other two.....paste follows.
General #0
Complete name : G:\AAA\RtPh264.mov
File size : 299 MiB
Format : Quicktime
Overal BitRate : 69650 Kbps
PlayTime : 36s
Video #0
Codec : H.264
Info : H.264 (3GPP)
Bit rate : 68112 Kbps
Width : 1920
Height : 1080
Aspect ratio : 16/9
Frame rate : 25 fps
Bits/(Pixel*Frame) : 1.314
PlayTime : 36s
Audio #0
Codec : PCM
Bit rate : 1536 Kbps
PlayTime : 36s
General #0
Complete name : G:\AAA\RtPHD.mov
File size : 2.95 GiB
Format : Quicktime
General #0
Complete name : G:\AAA\RtPSD.mov
File size : 564 MiB
Format : Quicktime
Overal BitRate : 131518 Kbps
PlayTime : 36s
Video #0
Codec : rle
Bit rate : 129980 Kbps
Frame rate : 25 fps
PlayTime : 36s
Audio #0
Codec : PCM
PlayTime : 36s
Chris Muriel
That does seem a bit on the low bitrate side for HD (even if H264 / MPEG4 encoded.
I have seen 8 Mbps HDS streams that are reasonable quality though.
Chris Muriel, Manchester
arfster
If it was 720p h264 and only 24frames/sec, then maybe just - I've got a 6mbit copy of one of the Rings movies in that format, and it looks pretty good.
If it's mpeg2 though, you'd expect 2-4 times that high.
Similar threads
