hi-def plasma to pc
Discussion in 'TVs' started by chaddy, Jul 7, 2005.
  1. chaddy
    chaddy
    Jul 7, 2005
    1,617
    48
    Manchester
    +66
    hi peeps 1st post, hope you can help.
    I'm getting a panasonic th37pv500 on monday, now i've downloaded some hd clips to show off its power.
    Now i'm just wondering what resolution do i sent my graphics card too ?
    cheers
  2. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,084
    Welwyn, Herts
    +825
    The same as the native resolution of the display, which I believe is 1024 x 768. I think most modern cards have that as a preset option.
    Remember WMV9 isn't the be-all and end-all of HD.
  3. Dutch
    Dutch
    Dec 5, 2002
    2,590
    3
    North Yorkshire
    +278
    The native resolution of the 37PV500 is 1024x720.
    Steve
  4. image165
    Sep 30, 2004
    145
    +3
    Surely the PC will output the WMV-HD video non-anamorphically, so it will have letterbox bars. Right? In which case, how do you get your PC to output a WMV-HD video anamorphically at 1024x720, so that it makes use of all the pixels on the Panasonic Plasma TV?
  5. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    You don't, the TV does the trickery. The video will be predetermined as to its resolution, so there's nowt the user can mess around with to change that.
  6. image165
    Sep 30, 2004
    145
    +3
    So basically, all you have to do is connect a PC to a Panasoinc 42PV500 (via the PC input socket), play back a WMV-HD file in Windows Media Player, and it will fill the plasma screen, with a beautiful high-definition picture, right? That sounds surprisingly easy. Infact, too good to be true.
  7. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,084
    Welwyn, Herts
    +825
    We've all got PCs.
    Just try experimenting with changing the display settings.
    Yes, it is that easy.
    Nick
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    This has also been discussed in the plasma forum. Unfortunately the 37PV500 does not, AFAWK, accept native rate on any input, your best bet is 1280/720 on digital, with a DVI-HDMI cable. With a PC signal there is a fairly hideous amount of overscan. A common problem with TV plasma, that's why everyone bangs on about display models so much.
  9. peterho
    peterho
    Jan 21, 2005
    58
    east yorks
    +8
    what lead do i need to connect my Sony 415b laptop to my Hitachi 7200 to watch hidef video clips on windows media player,sorry if it seems a stupid question ,I am baffled by the jargon.
    thanks Peter
  10. chaddy
    chaddy
    Jul 7, 2005
    1,617
    48
    Manchester
    +66
    tried it today with my new panny pv500, couldn't get the resolution right with dvi to hdmi, was to big for screen.
    Changed back to the d-sub & it was perfect, shame that my pc couldn't handle wmv-hi-def clips when connected to the panny, it can do it on my grundig 17" LCD but not on the panny
