hi def pack
Discussion in 'Nintendo Forums' started by thewul, Oct 18, 2004.
  1. thewul
    thewul
    Oct 1, 2004
    275
    +15
    hi all,
    i want to connect my pal unmodded xbox to my projector and 5.1 amp so i really want component out and optical out for audio. the hi def pack has both but on the lik-sang web site it clearly states not for pal. :mad:
    I know i wont be able to run hi-def images but will the cable work with my uk xbox to give me the outputs above :confused:
    cheers
    mark
  2. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    Yes.. is the quick and easy answer to that. I had mine running like this for a few days before it was modded.
  3. thewul
    thewul
    Oct 1, 2004
    275
    +15
    :) great thanks :clap:
