Hi def downloads, free!
Discussion in 'Plasma TVs Forum' started by explorer, Sep 20, 2005.
  1. explorer
    explorer
    Aug 20, 2005
    49
    Richmond, Surrey, UK
  2. mine
    mine
    Feb 8, 2004
    128
    19
    88512 Mengen Germany
    if you want to smile even more :) go to
    www.apple.com
    and download some 1080p/H.264 samples
  3. bluecupra
    bluecupra
    How can you play these movies on an standalone Sony DVD player?
    Or isn't this possible?
    Jeffrey
  4. mine
    mine
    Feb 8, 2004
    128
    19
    hi jeffrey , its not possible
    you need a htpc with horsepower and decent graphiccard
  5. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +16
    Ht Pc?
  6. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +16
    Got it Home Theater PC, whats the best way to connect a PC to plasm, just use VGA Cable? or can you buy a card with DVI out?
  7. explorer
    explorer
    Aug 20, 2005
    49
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I connect mine throught the VGA, set my PC to native res (1024x768), adjust the settings in media player to get the correct ratio (1.33) and hooray, hi-def demos playing on my plasma. :thumbsup:
  9. jedi-jae
    jedi-jae
    Sep 23, 2005
    586
    +11
    I have a number of Media Player 10 HD vids and now some QT7 ones too, I've only just bought a plasma and would like to view these vids on it, is it simply a question of connecting my PC to my plasma with a standard PC connection lead?
  10. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    Yes, Best connection would be to use the Dvi output but a VGA - VGA cable will do or you could use the TV out if thats there but don't expect good quality from this connection.
    My HTPC is set up for a dual output, i use the PC Dvi output for connection to my HDMI on the plasma's media box, for displaying an up-scaled Sky+ feed and i use the PC VGA output to the VGA input of the Media Box for surfing, email and games.
  11. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Jedi, is that the 32PD Hitachi? If you have a VGA port, just a VGA connection at 1024x768 will get you a fairly good picture. Your screen is a tad limiting with PC signals, what we call native resolution is not available to you. 720P via DVI should work at 60Hz of course, and 99% of WMVHD stuff is 60Hz anyway, so no prob there. The slightly bigger issue is overscan, which only a great deal of patience can cure, and maybe at the expense of spoiling the digital picture. The overscan is sufficient usually to lose the task bar, a bit irritating. Not a show stopper for the odd bit of HD though. Dr HTPC has an idea there, to use both inputs as seen fit.
  12. docnaz
    docnaz
    Jul 17, 2005
    119
    16
    London
    Hi, sounds like fun. Is the display on the monitor in hi def? My monitor in "settings" goes up to 1280*1024 pixels. Tx
