Hi-Def connections in future
Discussion in 'LCD & LED LCD TVs' started by estherjon, Nov 16, 2004.
  1. estherjon
    estherjon
    Hello,
    Have (almost) decided to upgrade to a Sony 26" LCD (KLV-26hg2) and a Pioneer DVD (575A). TV input and recording will come via Sky+. What's worrying me slightly is whether the single component video input on the Sony will be enough when Sky's hi-definition output begins in 2006. Is there such a huge advantage to component inputs over other connectors or should I just bite the bullet and not worry?
    Any advice greatly appreciated as indeed are comments on my choices!
    Thanks,
    Jon
  2. Rob20
    Rob20
    Jul 3, 2004
    2,661
    103
    +388
    I don't think you can get hi-def through anything other than a component lead, dvi or hdmi cable. Though I may be wrong. Still, I reckon you should be looking for a tv with 2 component inputs. Or 1 component/1 hdmi/dvi lead.
  3. ccparkhill
    ccparkhill
    Oct 18, 2003
    500
    London, SE1
    +14
    Couln't you get an amp that does component switching like the Pioneer 814, which would seem an ideal partner to the 575 and would also allow you to play SACD/DVD-A?
  4. daveb975
    daveb975
    Oct 25, 2002
    3,997
    103
    London
    +276
    An amp with comonent switching would be ideal.
    My LCD has two component inputs, and was a key factor in my decision. On a 26" screen I find that DVD is marginally better via component than through RGB SCART, but that games consoles etc are a lot better.
    The Sony 26" is a good LCD, but a little limited on the connections front. Bear in mind that for around the same money (£1,350) you could have something like the Toshiba 32WL48, which has HDMI and component inputs, as well as a bigger screen.
  5. estherjon
    estherjon
    Thanks for replies. Unfortunately Tosh is out due to size restrictions but after reading all the threads this morning on HDMI I'm even more hesitant about the Sony - I seem to be falling into the classic trap of being paralysed by the fear of tomorrow's technology. Perhaps I'll just bite the bullet!
    Cheers,
    Jon
  6. daveb975
    daveb975
    Oct 25, 2002
    3,997
    103
    London
    +276
    It is easy to do.
    My Tosh 26" is for the bedroom, and I have no plans to upgrade my Denon DHT500 to a system that has HDMI/DVI output so it was irrelevant for me. If it had been my main TV, I may have been a bit more sceptical as well.
    If you are worried about digital connections, the new Tosh 27" has DVI, and I am sure that the next set of 26" screens will included DVI or HDMI capability.
    If not, the single component input on the Sony should not be a problem.
