Hi-Def and the Sharp LC26GA5E
Discussion in 'Televisions' started by Tomdale, Aug 18, 2005.
  1. Tomdale
    Tomdale
    Aug 7, 2005
    177
    According to the Sharp website I can receive HDTV through a receiver connected to the component input. Does this mean I would be able to receive the full hi def service from sky or ntl even although the TV set is not 'HD Ready'??
  2. scarty16
    scarty16
    Jul 1, 2003
    1,021
    +83
    Unless the content provider decides otherwise
  3. Tomdale
    Tomdale
    Aug 7, 2005
    177
    How do you mean?
    I am new to LCD & HDTV etc.
    If my tv has no dvi port will I still be able to get HD tv?
  4. AV Junky
    AV Junky
    Oct 30, 2002
    1,209
    Cheshire, UK
    +68
    Sky has said that the first generation of Sky+ boxes will have a component output which would include HD output. However, it will only be usable if the content provider allows the prgramme/film to be transmitted without HDCP copy-protection (since this only works over a digital connection).
    Bear in mind also that, over time, more and more programming will more than likely become HDCP only, as more people go out and buy HD Ready sets.
  5. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    HD can be transmitted digitally and analoguosly - in the case of the former, you'll need a DVI or HDMI connector. In the case of the latter, you'll need a VGA or Component connection.
    As a non HD-Ready TV, your DVI connection will not have the HDCP implementation necessary, so HD material will only be displayed at 480/576p whereas the VGA or Component will do the full 720p/1080i that the signal happens to be.
  6. dsb
    dsb
    you might want to check out the sharp models that have DVI or HMDI - although they cost a bit more.
