"Hi-Bit" on Pioneer AX5i and AX5ai
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Dec 23, 2004.
Tags:
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    I have a Pioneer AX5Ai and wondered what the "HI-BIT" function is for. It says that it increases dynamic range for SACD, DVD-Audio and DVD-Video discs, yet the default position is "OFF". Can anyone tell me in a bit more detail what it does and should I be using it for optimum sound quality?
    Thanks, Martin.
  2. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Simplistically speaking, the hi-bit function does some post-processing on the sound source in order to make it sound a bit better.
    Of course it can't create detail that isn't present in the original recording, but what it can do is smooth off some of the harsh edges present in lower bitrate sources.
    As a simple illustration, let's take the example of CD audio and DVD audio.
    CD audio samples at 44KHz, which means that it samples the audio 44,000 times every second. On the other hand, DVD audio can sample at a much higher 92KHz.
    Now let's think about representing a sound waveform digitally. The original waveform (before recording) would have been a perfect curve, but to represent that curve digitally, it has to be broken into 'steps'. With the lower bitrate CD audio, these steps are relatively large, resulting in relatively large jumps between audio samples. DVD audio on the other hand has a higher sampling frequency, so the steps are smaller, resulting in a more accurate representation of the original waveform.
    Put simply, the hi-bit function attempts to smooth off the steps using interpolation, with the result that the sound (usually) more closely represents the original waveform.
    For the most part it results in a better sound.
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Thanks. So you suggest keeping "HI-BIT" on for movie soundtracks and SACD's then?
    Thanks again. M. :thumbsup:
  4. Phill1978
    Phill1978
    Oct 15, 2004
    2,045
    48
    +84
    wouldnt have thought SACD`s would benefit ??
  5. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Thanks. So you suggest keeping "HI-BIT" ON for movie soundtracks then?
    Thanks again. M.
    M.J.
  6. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Hi-Bit on for everything except DVD-Audio, SACD and DTS 96/24 :) (for which the amp will automatically switch it off anyway)
  7. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Oh, and turn on MIDNIGHT mode too - makes a big difference to the perceived richness of the sound below -20dB volume (at which point it switches off automatically anyway)
  8. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Huh???? :confused:
  9. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Midnight mode is designed to compensate for low volume levels, which (on a THX amp) is anything below ear-shattering.
    Try listening to something at -30dB with and without midnight mode... you'll soon see what I mean.
  10. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    I normally have mine at about -15db but with MIDNIGHT MODE OFF. Will MIDNIGHT MODE ON at -15db be too loud? What settings do you have on your amp?
    Thanks for all your help :thumbsup:
  11. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Midnight mode only functions below -20dB - above that it has no effect upon the sound. I have it turned on all the time because I use my amp for regular TV and background music as well as in-your-face movies etc.
