Hi 8 - stuck editing - please help
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by bean, Aug 16, 2003.
  1. bean
    bean
    This is the first time I have posted but I am desperate for help - I hope this question hasn't been asked before.
    I have got a hi-8 camcorder and am not sure how to edit the film I make. I can play back on the TV without problems and thought I could use my VHS recorder to edit the film (in a crude way). However I can't get this to work. Is there a way to edit without using a computer? Is there a small edit machine that I can use? I'm beginning to wish I had spent more money to get a digital camcorder now! Any ideas?:hiya:
  2. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    You should be able to do some very crude editing with you VCR as you have said.
    How have you set it up?
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,269
    Rainham Essex
    +2,405
    A VCR can be used for very simple editing, but the results will be very hit & miss :nono:
    Standalone editors can be bought, but will cost a lot of money. IMO your best bet will be to get a USB 2.0 card (if your PC does not already have USB 2.0) from around £15 and then get a USB 2.0 analogue capture device from the likes of Belkin etc. from around £60. These can be bought from PC World :)nono: ) or most PC hardware internet sellers.
    With the exception of quality you will then be able to do everything that you would have been able to do with a digital camcorder, ie add titals, transitions etc. and the editing will be far more accurate.
    If you do want to go the external box route then take a look at www.keene.co.uk who have a very basic solution from around £50 and then up to £200+ :eek: for more advanced units.
    Mark.
  4. bean
    bean
    Thanks guys - will give it a try when I have upgraded my computer -- it crashes at the slightest thing at the moment.
