ok,have no problems transferring my Jvc mini dv to pc via firewire, and then burning to dvd works a treat, i use MGI 5 to capture edit etc and then convert to mpeg2 then ulead movie factory 3 to make a template add a music track opening title and then burn to dvd... a friend wanted a hi-8 movie done the same way !! so done exactly the same connected via firewire as i would with my jvc minidv etc,,,,, and when they played it in their dvd player after about 25 mins it starts to stick like for a second or so then moves a bit then same !! ... very annoying and a dent in my ego !!!...
am using windows xp pro
2.4 ghz 512 ram... before converting i use end it all to kill all non essential programmes....my dvd burner on my pc is a 16x lg....?? any one got any ideas.. could it be the other persons dvd player ??...
help please....
help please....
