I'm really struggling to find a conclusive answer to my question on backing up footage.
I'm set on the HF100 now but i dont have a clue how to make DVDs from the footage to backup so i dont need loads of memory cards (which is crazy).
1) I want to be able to make standard DVDs that will play in everyones players.
2) I also want to be able to make HD DVDs so i can make use of the full HD on the HF100.
3) Also if i record the footage to a normal DVD will it loose its HD PQ by noticable amounts or because it was a HD recording will it still look better on a SD DVD than if it was SD recording to SD dvd?
4) I assume the only way to watch the HD recordings without having loads of memory cards is to run them from a laptop into your TV? Which is a bit of a hassle to me - i'd rather just have all footage on DVD - so i want creating DVDs to be easy.
Thanks in advance,
Thanks in advance,
