HF or LF speaker wiring question
PSM1
As long as the jumper bars are in place (or a bit of cable) then it really should not matter which one you connect too since the electrical side will see the same circuit.
BlueWizard
True is doesn't matter as long as the Jumper Bars are in place, but I would still connect to the LF terminals. That means a direct connect to the bass drivers, and the lesser signal to the tweeters gets passed through the Jumper Bars.
Though again, technically it shouldn't matter.
However, I found the Jumper Bars on my Wharfedale Diamond 9.6 to be unreliable, so I replaced them with short speaker wires with gold Ring terminals.
Steve/bluewizard
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
