Hex codes for yamaha rx-v671???
nyr900
Hello,
I recently bought a yamaha rx-v671, and I am using a URC MX880 universal remote. I love both products and both are working well together except two commands which are important.
I need to learn the universal remote to do the "on screen" command and the "enter" command, which are on the stock remote for the yamaha. Every-time I try to learn the command, it says the command has been learned, however it doesn't work. URC recommends getting the hex codes from yamaha, however getting through to yamaha is about as hard as you could imagine.
Anyone who can help me with this I would really appreciate it..
Thanks, and happy holidays.
Bill
Loada
I assume you mean the Pronto IR code - it's been a while but can you try this to see if I've remembered how to decode these correctly:
On-screen (Main):
0000 006D 0022 0002 0157 00AC 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
nyr900
thanks, i will try that... so all those numbers are just for one command?
i need the codes for "on screen" and the "enter "button....
Crustyloafer
Can I assume by 'onscreen' you are looking for the setup menu code?
Onscreen
0000 006D 0022 0002 0155 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 05ED 0155 0055 0015 0E47
Enter
0000 006D 0022 0002 0155 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 05ED 0155 0055 0015 0E47
nyr900
by on screen i mean the button on the yamaha remote called "on screen" .... it is basically a setup command which allows you to go into the settings on the receiver and make changes... where did you find these codes? are you some sort of wizard hahah?? I really appreciate your help and I am trying this right now as we speak.
nyr900
neither one worked...... i called URC (remote company)and they said i am entering them in properly, just probably the wrong code....
Crustyloafer
I am an installer and I deal with Pronto Pro, Nevo and RTI remote control systems. I got the codes from the RTI database for a similar model.
Try these:
Setup:
0000 006D 0046 0002 0155 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 05ED 0155 0055 0015 0E47 0155 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 05ED 0155 0055 0015 0E47
Enter:
0000 006D 0046 0002 0155 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 05ED 0155 0055 0015 0E47 0155 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 05ED 0155 0055 0015 0E47
Crustyloafer
Or
Setup
0000 006E 0022 0002 0154 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 05A6 0154 0055 0015 0E28
Enter
0000 006E 0022 0002 0154 00AA 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 05A6 0154 0055 0015 0E27
nyr900
Well the codes did work.... however they only worked when i did a "test" phase in the software for the remote.... it does not wok when I physically disconnect the remote and try and use the buttons.... i doubt you can help me from here... i wish you could though... thanks so much for your help this far
Crustyloafer
Which codes worked?
If they worked in test mode but not independently than that would suggest to me there is a fault with the remote itself.
