Here's one for any Sony HDx owners...
Discussion in 'Headphones, Earphones & Portable Music' started by redtom, Sep 20, 2005.
  1. redtom
    redtom
    May 31, 2003
    50
    ... a little bit anal to be sure, but which uses more power - having your screen on positive or negative?
  2. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    This was discussed before. The answer was, negative uses slightly more but it is such a tiny amount it would make no practical difference. Its the backlight that uses all the power.
  3. shadowritten
    shadowritten
    I thought positive used more?
  4. sk79
    sk79
    Jun 29, 2005
    36
    me too. Surely positive (BOW) settings mean that there are more white pixels, therefore using more power...
  5. drmoze
    drmoze
    Aug 8, 2005
    196
    that's not how it works. they aren't little light bulbs....
  6. AlexGarfield
    AlexGarfield
    dosent the neg use less becasue on the lcd the defalt(when you turn it off) is dark so it would take power to align the crystals to allow light through
    and no they are not little light bulbs thats OLED
  7. drmoze
    drmoze
    Aug 8, 2005
    196
    I'm pretty sure the display acts like most similar lcds. The panel is clear, and black pixels are formed by a very tiny application of charge (almost zilcho current) to change the polarity of the pixel area and make it dark, thus blocking the backlight from coming through. It doesn't work like little lights that use power for light pixels. The backlight is on behind the entire screen when lit. Only the polarity of individual pixels is changed to block the light. Doesn't use any noticeable amount of current.
