A couple of months ago I was looking for a cheap way of getting my PS2 connected to my WAP. It seems stupid but all I could see were Wireless Ethernet Bridges that cost more than some WAPs. Fortunately a new product was released in Feb which seemed to fit the bill.
I've now been using it for a month and can't fault it. It's called the Asus WL-330. Not only is it an adaptor but it can also work as a WAP (802.11b) if you want. The kit you get is impressive. It includes the WAP which is extemely light, a power adaptor, a USB power supply (saves on a plug when using it with a USB piece of kit), a nice very short ethernet cable and a carry case/pouch for it all.
The browser interface is easy to use and it comes with a CD but I haven't bothered to even look on it. I simply connected it to my pc (which I configured to be 192.168.1.2), ensured the WL-330 was in adaptor mode and not WAP mode (a slide switch on the bottom) and then in my browser went to http:\\192.168.1.1
This brought up the config page. I simply told it the name of my WLAN, typed in my 128bit WEP encrption key and saved it.
I then took it down to my PS2, plugged in the ethernet cable, plugged the power lead into a USB port on the front of the PS2 and powered the PS2 up. I loaded up MOH Rising Sun and it worked on-line straight away!!
The picture above makes it look a lot bigger than it is so here's one to give you some scale :
The cost inc p&p was £36 inc VAT and p&p. Even though I am only using it as a ethernet/wireless convertor and I'm not using it as a WAP, I still think it's great value and it take up virtually no room behind the PS2 & TV.
Can you tell I'm pleased with it?
Ooops nearly forgot. Here's where you can order from :
http://www.spd.co.uk/product.asp?sku=287&dept_id=26
p.s. I have no connection with the manufacturer or supplier other than being a really happy customer.
