G
get1a2get1a2
Panasonic DMRE500
Plays pre-recorded DVD's & CD's
Built in analogue & digital TV tuner
Ethernet connection for networking
DVD-Audio (5.1) playback
Built-in Dolby Digital and DTS Decoders
HDMI output
MP3 Playback
DVD Audio Playback (Stereo)
Records on DVD-RAM & DVD-R Video Blank Media
Will make discs that will play in most existing DVD players (DVD-R only)
Uses VBR (Variable Bit Rate) Technology to maintain high picture quality
Videoplus+
Playback programs recorded to DVD-RAM or HDD while watching another program on DVD-RAM or HDD
Internal 400GB HD for time shifting
High speed transfer (22 Mbps) to and from HDD to DVD-RAM
When transferring at 1x speed from HDD to DVD-RAM or DVD-R, formats can be re-encoded eg XP mode > EP mode)
Allows non-linear editing to transfer to DVD-RAM and from DVD-RAM to HDD
Playback while recording even at high bit rates (HDD and DVD-RAM)
Uses the single layer 4.7GB DVD-R (once only) system and DVD-RAM 4.7Gb systems
Records in real-time using MPEGII compression-Up to 6 hours per DVD-RAM disc
Quick recording function automatically finds the blank part of the disc
Variable Data rate and variable resolution settings
Disc navigation thumbnail chapter view
Built-in time base corrector that delivers highly stable, natural images
Front A/V input
Full RGB in and out
Flexible recording mode allows you to manually a time for recording and the player will set the best possible bit rate for that time, say 1 hour 15 minutes to fill a disc
Can record and playback NTSC and PAL
Progressive Scan (PAL & NTSC)
Firewire (i-link) DV input
PCMCIA PC Card upgrade slot
SD Card Reader for JPEG, TIFF and MPEG4 playback
HDMI output
MP3 Playback
Videoplus+
Front A/V input
Full RGB in and out
