Hepl With Yamaha AV Receiver Please
Senrap
I have bought a Yamaha RX-V450 from Germany and I will no doubt need lots of help setting it up!
However my first question is what is a 75-ohm/300-ohm antenna adapter because it only comes with the UK model and therefore was not included.
I guess it's something to do with the AM or FM reception.
Do I need it and if so any idea where i get it from - Yamaha UK perhaps?
Thanks for any advice you can give.
C
chunderwunder
Not sure myself. i've just got a 1500 from Germany. it says the same thing in the manual. I just used the 'thin FM aerial' thing at it seems to work fine.
Senrap
Thanks Chunderwunder
I had my brother in law round this evening and fortunately he's got some common sense. He said it is not needed as I don't have the UK model!
Thanks for troubling to reply
