Help !
Discussion in 'Desktop & Laptop Computers Forum' started by 50/50, Mar 20, 2003.
  1. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    I have got a yamaha CW2200(or something like that) cd writer. It has been fine for the last 2 years. But over the past 2 days it wont burn a cd without the buffers suddenly going down really quickly:confused:, and eventually saying that it couldnt complete disc-at-once.
    Nothing has changed on my computer, I have tried different speeds but the same thing happens.
    Any advice ?
    BTW. I am using Nero V.5.5.10.0
  2. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
  3. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    If it makes you feel better i've got a creative jobbie thats about the same age. It now burns a CD tells me it fine and verifys it, then try to look at the files under window, and theres nothing there, i take the cd out and nothing been written??? :confused:
    Open nero up again and it reads it as a blank disc, sometimes it work others it doesn't. I put it down to a doggy drive that wont burn when it gets hot. It does it using other software other than nero too.
    Spunky
