Help!
Discussion in 'Computer Components' started by Dan Walton, Sep 22, 2007.
  1. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    Okay, I've jsut bought a new sound card for my PC from Maplin, it's an Apollo PCI 5.1, probably notgreat but I just wanted something with an optical in. I've slotted into the PC and installed the drivers, but it's not really making any sound. It's just making noises. If i try to play some music it just sounds like static, and the normal clicking noises from selecting icons when on the interent are just bursts of noise. I've got my normal PC speakers connected to it through the front channel output. I don't get why it doesn't work, any ideas, or should just take it back!? There was a Trust sound card that the guy said looked identical, but a little dearer, so he said I may aswell go for the cheaper one!
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    Could be a conflict.
    Check in device manager to ensure there's nothing obvious.
    You could also try disabling the soundcard in the Bios, if it's built into the motherboard.
  3. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    Umm...
    Did I metinon I'm a bit of a computer numpty!?
    All I can say is that when I put the speaker jack back into the original connection (I'm guessing this is what you're referring to on the motherboard) I get nothing out at all.
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    click start,control panel, system, hardware, then device manager.
    Look for any yellow exclamation marks or red crosses.
  5. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    Bah! I've just uninstalled it and removed it now! I'll put it back in again and try that then.
  6. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    Okay, I don't know why, but after installing it all for the third time... it's working! Thanks for your help all the same though!
  7. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    Bonus!
    At least it's working mate :thumbsup:
  8. Dan Walton
    Dan Walton
    Apr 20, 2006
    162
    Basingstoke
    +3
    But I've now realised it won't be able to help me do what I wanted it to.... :suicide:
  9. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    :rotfl:
    Bad luck mate :thumbsdow
  10. Xerstead
    Xerstead
    Mar 26, 2004
    164
    +15
    I still haven't figured out why computers do that.
