HElp
Discussion in 'LCD & LED LCD TVs Forum' started by trav2006, Dec 24, 2006.
Tags:
  1. trav2006
    trav2006
    Hi just had a new tv GOODMANS GTV26wlcd ,was wodering if anyone could help me out with whats the best output from sky+ pal or rgb and also the settings of brightness etc cant seem to get any of them right to get the pic looking clear......Generally whats the basics setting required on both tv and sky+ box to ensure iam gettin the best out of it...
    cheers
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    Seasons greetings my friend, try to connect up everything using good quality scart leads. Ditch the freebie ones and invest around £15 on a couple of decent leads. Then set up the inputs and outputs of all equipment to RGB. Then using oneof the THX optimode menus on many DVDs, Toy story 2 I think has one. Use these settings for the best picture.
