Help.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by AQU4RIUS, Mar 25, 2006.
  1. AQU4RIUS
    AQU4RIUS
    Oct 16, 2005
    432
    +23
    ive just preordered SkyHD, and realise it has Sky+ included.
    iam currently a Sky subscriber, but am using a communal dish that is NOT sky+ compatible.
    now is there anyway of splitting the signal from this dish to work with Sky+ ?or am i goin to have to be a naughty boy and put up a dish even though im not really allowed.:nono:
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    no is the short answer, you just wont be able to use the record facilty, the only other thing you may be able to do is if one of tyhe other flats do not have sky is
    take their cable, but check with the building owner first
  3. AQU4RIUS
    AQU4RIUS
    Oct 16, 2005
    432
    +23
    but doing that is surely the same as putting a splitter on the cable?
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    No, it isn't. The Sky box sends signals to the dish to select polarization and hi/low band ranges. You need two completely separate feeds.
  5. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    thanks nick
  6. AQU4RIUS
    AQU4RIUS
    Oct 16, 2005
    432
    +23
    i guess im gonna have to put up a cheeky dish!:devil:
    cheers!
  7. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    I thought you could buy a niffty box so that Sky+ would work from just one feed (sorting out all the polarity issues on the way)??
  8. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    surely if you could SKY would use this instead of running another cable and replacing LNBs
