Help!!!!
Discussion in 'Projectors, Screens & Video Processors' started by dyl33, Mar 25, 2006.
  1. dyl33
    dyl33
    Feb 14, 2005
    24
    Manual screen just installed
    screen now locked in position fully down .I am unable to get back up in the home position
    is there a overide type thing that i can do to get it to work (by taking off the side brackets to show the workings?)
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    Have you tried, pulling down the screen while banging the top case?
  3. Jonesey
    Jonesey
    Dec 10, 2004
    343
    28
    London
    +29
    I had a manual screen and had terrible trouble getting it back up. The only way I could get it back into the casing was to pull on the tab very sharply and let it roll back up by itself (ie, dont hold it on the way up). this made a rather large bang when it hit the top, but it was the only way it worked. i ended up taking it back to get an electric one.
    good luck.
