help
Discussion in 'General Chat' started by mckayajmc, Jul 26, 2005.
  1. mckayajmc
    mckayajmc
    My room is 13.6ft * 12.4ft I want to know what is the maximum size screen I can use and the best place to perches it from. I’m in the process of creating a dedicated room for my home cinema and need as much advice as possible on the best equipment needed for the budget I have. Which is only £25,000 I know this is not much but the rest of the budget is going towards getting the room to a liveable standard
    thanx to those of you who have repliyed and yes it 25,000 and not 2,500
    i have to get everything from the screen to the dvds films them selves i mean do i go for sony phillips or panaconic
  2. themoid
    themoid
    Oct 23, 2001
    879
    Staffs
    +30
    you think £25k isn't much of a budget :eek: :eek:
    what do you need to buy - are you talking the lot - speakers, cables, receiver, dvd player, projector, screen etc etc ??
    there are many recommendations in the individual subject groups on the forums for different items of kit - may be worth you taking some time to have a look through these to focus down to some questions on specifics...
  3. Dr Diversity
    Dr Diversity
    £25, 000 not much - spot the newbie!!!
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    maybe should be £2,500? £25k will get you a **** load of gear
