Discussion in 'Projectors, Screens & Video Processors' started by JohnRaymond, Apr 30, 2005.
  1. JohnRaymond
    JohnRaymond
    Jan 5, 2005
    54
    11
    Appley Bridge, Lancs
    +4
    I have just got my et1 home and I can get the dvd to work fine.
    Just have to wait till its dark now though as I currently have no curtains up in the room its in.
    My problem is I want to connect it to my philips dtr1500 freeview box.
    Must I buy a scart to s-video convertor as the freeview box has no s-video out.
    It wont seem to work with just scart from box to et1.
    thanks in advance
    john
  2. mi_july
    mi_july
    Do you know for certain that it can output an svideo signal? I would output it over RGB and then use a converter to change the signal to YUV, works v well, but obviously enduces extra costs.
  3. JohnRaymond
    JohnRaymond
    Jan 5, 2005
    54
    11
    +4
    It was me being a plonker
    I had it on the wrong input....doh!!
    So, I have used a converter from scart to vid/audio 1+2 (yel/red/white) into the ET1 audio sockets.
    The dvd I have scarted into the freeview box so both signals can be switched from the freeview remote.
    One thing that confused me though now i have spent all day doing something that would take you people 10 minutes is that I can only get black n white to the et1 direct from my dvd via s-video, though all is well with scart.
    Any ideas?
    john
  4. andyfel
    andyfel
    Hello mate, I have the same problem with my Sharp PJ. Its ok with SVGA/D Sub, but erratically it goes B&W with composite or SVHS!!
    Have you sorted your problem out!
    I to have a Phillips DTR1500 free view box and sometimes i get B&W why?
  5. dancingmatt
    dancingmatt
    Apr 26, 2005
    433
    +13
    You sure your DVD/Freeview source outputs in S-video? Most scart sockets only do RGBH or composite, not s-video. Maybe that's your problem?
