Help.
Discussion in 'Blu-ray & DVD Players & Recorders' started by pauwoo, Mar 12, 2005.
  1. pauwoo
    pauwoo
    Mar 12, 2005
    I have a quick question, i have finally got myself a plasma tv, a Hitachi 42pd5200.
    I have had a Denon 2900 for a long time, this has prog scan on it for both PAL and NTSC, i have connected to my plasma via the S-Video connector, if i turn the prog scan on, will i see a better picture or does it have to be using component connectors for this to work?
    I am going to get component connectors any way but was just wondering if this would do for now?
    thanks
    paul.
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    Didn't think you could get progressive through the S-Video connector. My 3910 is hooked up using HDMI-DVI and Component and it plays rather nicely :)
    I may well be wrong (only thing I use S-Video is for my PS2) but I'm pretty sure.......
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,602
    Rainham Essex
    +2,543
    Sadmuppet is correct, the only analogue connection to work with PS that is common on a DVD player is YUV component. RGBHV can also carry PS but is not on that many DVD players and if it is is normally via a VGA connection.
    DVI & HDMI can also carry PS in the digital domain.
    Mark.
