Jeebus said:What are you watching it on? Sky? Xbox? Blu ray player? It all depends on what source you are connected to.
Ahh thanks no wonder I thought so however I'm sure I can improve quality from 586p I have the v+ box output with hdmi cable
Just re-read your post and I do in fact have a v+ hd box
vickster said:Do you have the V+ HD box set to 1080i HDMI or similar (I can't remember what it need to say)Then you should see HD when you are on a channel with an HD programme on. How far do you sit from the TV - unless you are quite close, even then the picture may not seem as good as you expect
