apriliamgt
Ok im not sure what ive done.
Ive had problems booting for awhile but now after playing around with a few bios settings nothing is now happening.
I was playing with CPU set-up in the bios. Ive attempted to reset the cmos/bios by removing the batt and the jumper settings.
Everything comes on as it would normally but nothing appears on screen ( no signal)
so now my computer is laying there doing nothing.
my motherboard is Asus M4A88TD-V EVO.
any input would be great.
Ive also removed the video card and used onboard and nothing is happening there either. used HDMI/DVI and D-sub and nothing
memory test is ok aswell
