Help!
Discussion in 'AV Receivers & Amplifiers' started by m29ke, Oct 3, 2004.
  1. m29ke
    m29ke
    It's the first time i have been in one of these forums. I have just purchase an AV reciever in a open box sale @ Richer sounds. However there is no remote or manual with it. Does anyone know where I can get these items. Thanks in advance.
  2. m29ke
    m29ke
    Kenwood krfv 5050ds
  3. BrianC
    BrianC
    Jan 20, 2003
    2,190
    +101
    heres the link to the manual:
    http://www.kenwood-electronics.co.uk/languages/EN/support/manuals/KRF-V6050D-5050D(EN).pdf
    you could also ask kenwood support (see link above) if they will sell you a remote, but its probably cheaper to get a universal remote that has the kenwood IR signals pre programmed onto it.
  4. m29ke
    m29ke
    Thanks Brian for getting us the manual, I couldn’t find it anywhere!. I’ll take your advice and get an all in one remote :laugh:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Amp set up may require remote....... mate bough one of those at open box 2 years ago same state and went in to return it and they rummaged in a box out the back and found one...
  6. m29ke
    m29ke
    Nice one! I don't think they had a spare remote in the shop i'll probably have to try Kenwood
