Help!!!
Discussion in 'General TV Discussions Forum' started by Biccy, Sep 20, 2004.
  1. Biccy
    Biccy
    Just switched on my new 36zp38 & for some reason it keeps putting itself on standby?! Anyone had this problem, is it me doing something stupid?
  2. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    chances are that a fault has occured with you set. Does the stanbye light flash?
  3. scottiefraser
    scottiefraser
    Sep 20, 2004
    574
    46
    +186
    Can you switch the Tv on via the remote at all once it goes onto standby?? If you can it might be that the Panel Lock is switched on from the menu which stops you using all of the front buttons including the power button. It will switch straight onto Standby and will only let you turn it on via the remote if this is the case.
  4. Biccy
    Biccy
    thats exactly what was happening when i got set home & first used it last night but today its been fine (turned itself off once all day), however the panel lock was off.
