Help!
Discussion in 'Cables & Switches' started by mevetts, Aug 3, 2004.
  1. mevetts
    mevetts
    Oct 31, 2003
    439
    Hi Everyone,
    Ok, this is the kit I will have within around 8 weeks.
    [​IMG]
    [​IMG]
    I will also have my VCR, which has RGB scart, and a set of Canton CD1's.
    My tv is only an average 24" with one scart socket at the back! :(
    I already have some scart leads that I could use and they aren't rubbish, so am happy to employ them in my new set-up.
    Questions!
    1. The receiver only has clip terminals, not the best, but will suffice for the amount I'm spending. So I will need some speaker cable :laugh: ! Will some joe bloggs stuff do? Is there a few things I should look for? I do have some old hi-fi cable I could perhaps use somewhere?
    2. Do I need a subwoofer cable? If I do, how much are they? Where's the best place to go? tvcables.co.uk?
    3. What is the best way of connecting the DVD player to the amp? Co-ax interconnect? Again, would a no brand cable be ok or perhaps a Mark Grant cable?
    4. How should I connect the VCR to the amp? Scart?
    I have a max budget of £450. The rec will hopefully only cost me £160 and the Cantons £250 max. I reckon that leaves approx £40 for cables, not much I know, but I do not mind upgrading in due course! :laugh:
    Thanks for any help, it really is appreciated! :rolleyes:
    Mark.
