Help!!!!
Discussion in 'Desktop & Laptop Computers Forum' started by scouse, May 26, 2004.
  1. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    Hi everybody, my computer is playing up. Can you help???
    I have an abit nf7-s motherboard with an athlon 2500+ cpu and 512 mb ram.
    In the last week it intermittenly boots up but won't start windows xp pro up saying "a hardware or software change may have caused this" and gives me options to continue.
    I'm not really knowledgable about these things but I've tried pushing possibly loose connections and that sort of thing, and taken off any software that i'd put on previously to the problems occurring.
    Any ideas? :lease: :(
  2. mps
    mps
    Oct 16, 2001
    1,588
    London
    +57
    Have you tried system restore?If you dont know how click Start,All Programs,Accessories,System Tools and select System Restore.
    Good Luck. :thumbsup:
  3. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    what will that do btw? I won't lose all the the data on my hard drive will i?
  4. mps
    mps
    Oct 16, 2001
    1,588
    London
    +57
    No you wont.Think at what point you did something that it started to go wrong,then choose. :smoke:
  5. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    I've tried the system restore but the problem still occurred :-(
    Could it be a fan not working properly? The cpu fan sometimes makes a funny noise but this is not everytime it fails to load windows and restarts...
  6. mps
    mps
    Oct 16, 2001
    1,588
    London
    +57
    Have you or anyone else changed anything to your computer (hardware) or(software).
  7. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    I haven't changed a thing... i get one bleep when i start up if that's a help...
    Any ideas?
  8. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Reseat your CPU heatsink and check/change the CPU fan,might be an overheating problem.Better still,monitor the system temps from bios if you have that facility.
    Rob
  9. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    My system temp stays at 32-35 whilst my cpu temp is around 38-46 C . When it doesn't boot up usually the computer has a single low beep. When it does work there is a low beep followed by a loud more high pitched beep. Is that a help to anyone??
    The odd thing is, is that it boots up fine sometimes but then it can go through 6 attempts before it loads windows in other times...
    I thought an intermittent contact of some sort might be the problem but I'm not sure.
  10. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Memory........Memory refresh error I believe is normally what causes it after the POST beep.
  11. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    how can i be sure it is that and how would i fix it?
    thanx
  12. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Well, have you got another PC that you can borrow the memory from or a friend, relative, etc that will let you buy one?
    Go to a PC shop and ask them to test it, but you may have to imply that you are going to buy replacement memory from them.
    Go to PC World and check that if you "I am buying this for my relative for their birthday. If it's the wrong one, can I bring it back?" to confirm the problem.
    Worst case is that you take your whole PC to a repair centre and ask them to look at it so they can isolate the fault incase it is not the memory.
    Just a suggestion or two.
  13. mjn
    mjn
    May 24, 2001
    22,433
    Herts, England
    +10,470
    check the manual for help on start up beeps
  14. mps
    mps
    Oct 16, 2001
    1,588
    London
    +57
    You could load your win xp pro disc and select repair.Its worth a try,or scan your drive for virus check.
    Regards.
  15. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    I have seen this message if a hardware change has been made - but its normally when you are well into windows - can you access different boot options? Try booting into Safe Mode by pressing F8 when your machine is loading and see if it gives you any clues.
    One bleep often means your video card is in wrong / wrong speed - has it always been working?
  16. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Hi Gillykid,
    I was under the impression that a single beep after the post beep was a memeory refresh problem, and that 5 or 8 beeps after the post beep was graphics card problems.
    MJN has the best suggestion to check the manual as differnet BIOS manufacturers have ways of reporting faults.
    The codes I am reffering to are Pheonix and AmiBios codes which tend to be the norm.
    Some motherboards have LED's that indicate the fault - Providing the fault is hardware related..........
  17. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    thanks for all your input guys, i'm away this weekend so can't check right away but i'll get back to you with an update on tueday...
    the video card has worked since i've had it, i bought the computer from the forums here and it was only a few weeks old then.
    :suicide:
