Help?
Discussion in 'Plasma TVs' started by Ancillotti, May 20, 2004.
  1. Ancillotti
    Ancillotti
    Hey!
    I've noticed that when watching a couple of programs (The Simpsons / 3rd Rock From The Sun so far) that the screen aspect starts to change back and forth constantly, which is annoying to say the least. I know that you can manually change the aspect ratio to 16:9, but the swapping of aspect ratio continues. Also the 16:9 seems a little stretched i.e. the Paramount logo is slightly cut off on the right hand side. If I use the Panasonic Auto aspect function it creates a perfect 16:9 picture without the cutting of the logo, but then starts changing to a 16:9 stretched pictured :confused:
    The question is: Is there any way of aquiring this unstretched 16:9 without the aspect ratio constantly swapping? Is there any way to stop the swapping full stop? The RGB SCART lead is securely fitted.
    Thanks in advance! :thumbsup:
    Ancillotti
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    use something other than scart and you wont get the switching!
    ad
  3. Ancillotti
    Ancillotti
    RGBtoVGA convertor is it then ... :) Thanks!
