Quantcast
Help?
stegalv
How do i change the file format of the excel spl graph into a format that is accepted by these threads.
~Kev H~
There are probably other ways but...
If you have the window with the graph in as your active window and press Alt+PrintScreen then you get a screenshot saved to the clipboard.
Then open something capable of saving an image as a .jpeg, something like Microsoft Photo Editor which comes with the microsoft Office tools, and just paste the screenshot into and save the image as a jpeg.
Hope that helps - K
