Quantcast
Help!!!!!
sdm197
Hi Everyone,
I am still having problems trying to high speed dub on my DMRE-100, although I am using 4x Sony discs. I am trying to dub things recorded onto HDD back to DVD R like for like say XP-XP,LP-LP, but it just gives me a dialogue box saying this function cannot be performed, then defaults to whatever the HDD original was i.e. SP etc.
Has anyone actually got this machine to high speed dub properly, and how do you do it, I also have the machine configured to high Speed dub in the set up menu. Any replies would be very welcome.
kenfowler3966
Thats correct, you can only high speed dub at the original recording setting, ie xp to xp, sp to sp etc, whatever you chose when you recorded the original programme. To get anything else it has to re-encoded to the different quality, at normal speed I believe.
davee b
the E100 is a bit picky about the discs it uses, if it doesn't like 'em it might manage normally dubbing but balk at the high speed copy. :rolleyes:
OARDVD
I have had a 100% success rate with TDK 4X DVD-R discs on the E100. They have a grey top. I have recorded at least 70 of them (with probably about 80% of those being high speed dubbed at 4X speed).
vonhosen
Top quality discs :smashin:
sdm197
Thanks for the replies, I'm not sure whether my unit is faulty, or if its the Sony discs, has anyone tried or does anyone know whether 1x discs would work, or do they have to be 4x compatible, my knowledge is that they would have to be 4x, but I am sure I read on this forum recently that someone was using 1x discs to perform high speed dubbing onto DVD-R.:confused:
