Help!
ian dem
Established Member
Joined
Feb 21, 2004
Messages
285
Reaction score
9
Points
158
Age
48
Location
Liverpool
:confused: :(
I am running a sony davs300 dvd player to an rgb scart on my tv (sony kv32fx68),there is no scart on the dvd player so what cable should i purchase? I'm just using the one supplied at the moment.
Should i fork out for a good quality one & if so which do you guys recommend?
Originally posted by ian dem
:confused: :( there is no scart on the dvd player
Dude i may have taken this the wrong way but why dont you get a DVD player that hase scart on the back ??
I'm not entirely familiar with your components.
You don't need a player with a scart but does your player have an S-Video out?
And does your TV has an S-Video in? (this will probably be part of the secondary scart socket on your TV).
Check the manuals then come back. If you have both of these you just need a cable that goes from S-Video to Scart.
If your TV has a dedicated S-Video in that isn't part of a scart socket it's even easier; just get an S-Video lead of the appropriate length.
Unless your TV is ancient one of the scart sockets will accept an S-video signal which is the best quality signal output by the Sony DAV so you need a cable with an s-video plug on one end and a scart plug on the other.
You will probably have to tell the TV that the signal is s-video in one of the setup menus otherwise the picture will only be black & white.
It's important that it's an S-Video to Scart otherwise the pin connections in the Scart socket will be wrong (used for carrying scart to S-Video).
Hi guys,sorry i should have explained myself a bit clearer! Its actually a Sony davs400 & i'm connecting it to a Sony kv32fx68.
The davs400 has an svideo output so do i need an svideo/2 phono to scart cable then?
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
