Help Z1 powerstrip timings.
Discussion in 'Projectors, Screens & Video Processors' started by Splice, Jan 28, 2004.
  1. Splice
    Splice
    Mar 16, 2002
    153
    16
    Buckinghamshire
    Hi guys, a friend of mine has just gone and bought a z1 and i am supposed to be going to set up his machine could any of you z1 owners paste your timings on here for me to use. also i remember reading somewhere about a problem with z1 remembering the custom resolution, is this true, and if so how do you get around it. any help would be greatly appreciated guys.
    all the best...Splice ;)
  2. Splice
    Splice
    Mar 16, 2002
    153
    16
    Buckinghamshire
    anyone guys.....:confused:
  3. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    The Z1 remembers the custom settings but you have to switch it to the saved custom setting every time you switch it on. Takes a couple of seconds. Annoying but livable.
  4. Splice
    Splice
    Mar 16, 2002
    153
    16
    Buckinghamshire
    Cheers for that Calscot, but What are the settings/timings? as i cant find them anywhere in the forum through the search facility, and i have looked.
    Cheers. Splice :confused:
  5. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    I assumed someone else would have them to hand.
    I'll have a look over the weekend and get back to you on Monday.
    I think powerstrip has a option for 960x540 which give the same timings, why not try it?
    Cheers,
    Cal.
  6. Splice
    Splice
    Mar 16, 2002
    153
    16
    Buckinghamshire
    thanks, but i am supposed to be going over to this guys house tomorrow or sunday, so if anyone has them to hand, please can you post them pleeeeezzzzz :smashin: failing that i will try the inbuilt settings.
