HELP - Xbox controler dongle thingy....
Discussion in 'Xbox Forums' started by HSC, Jul 21, 2005.
  1. HSC
    HSC
    Nov 23, 2004
    1,910
    63
    Coventry
    +142
    post redecoration I have lost the silly bit of cable that you plug in between you console and the controller cable.....
    I dont particularly want to part with more £££ and get a new controller but I've searched the web in vain for a replacement...
    anyone know where to get one of these...?????
  2. willsy2
    willsy2
    Apr 22, 2005
    634
    28
    Newcastle
    +31
    Is it the piece about 7" long that plugs into the XBox with a din type socket on the other end? If it is, I got one free with a 8Meg memory card from Poundland, if you PM me with your address i'll bung it in the post.
  3. HSC
    HSC
    Nov 23, 2004
    1,910
    63
    Coventry
    +142
    What A Star...!!!!
  4. nigelbb
    nigelbb
    Apr 4, 2005
    5,268
    103
    +490
    It's not silly. The idea is that when you stumble across the living room & trip over the cable from your controller to the Xbox that it comes unplugged rather than you dragging the Xbox & TV onto the floor.
    cheers
    Nigel
