help wth ftp xbmc to laptop
Discussion in 'Xbox Forums' started by S600BYC, Jan 17, 2008.
  1. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    Hi please be gentle with me here i've read loads of guides etc but don't want to try anything that i can bu66er up! I've an xbox 1.2 fitted with a matrix chip (evox 3.6 eject flash) that works fine and have just created a disc with aid 4.10 on it. I've then managed to install xbmc as my dashboard but i'm now a bit lost as to how to connect my laptop to it through my crossover lead. Can someone helpme with a wee dit/ idiots guide for connecting the pair now? Thanks for looking, much appreciated:hiya:
  2. Chanser
    Chanser
    Apr 9, 2004
    1,946
    The Black Hole
    +290
  3. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    update-fingers crossed getting somewhere, cheers.
  4. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
  5. bigjb
    bigjb
    Dec 19, 2006
    4,902
    motherwell
    +433
    If you use flashfxp to connect laptop to xbox then it shows you the harddrives and partitions on both laptop and xbox and allows drag and drop between the two.
    If you get stuck feel free to post here or PM and i will try and assist.
  6. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    Thanks for that. Got xbmc now pointing to the right places for my laptop.
    C:\Documents and Settings\Scott's\My Documents\X-Box FAQ - CompuHelpForum.mht
    post7 helped me in simple terms!
    retro- just one query if i drag and drop is it going to remove it from one to the other or does it auto copy them across? Just i want to make a quick copy of c before i start playing and haven't played with flashfxp much before.:smashin:
  7. bigjb
    bigjb
    Dec 19, 2006
    4,902
    motherwell
    +433
    On mine it autocopies across and leaves the original in place.
  8. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    cheers, i'll try it on something wee to start with:D
  9. Chanser
    Chanser
    Apr 9, 2004
    1,946
    The Black Hole
    +290
    Love Flashfxp, best ftp program I've used so far.
