Question Help with ysp5600 soundbar please.
Discussion in 'Soundbars, Soundplates & Soundbases' started by dennis1, May 11, 2017.
  1. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Have had the soundbar for a month now and I just can't seem to get it set up right. I have used the auto set up mic but does not seem to give a good surround feeling, I have also played around with the distance and beam settings. At the moment I seem to be getting better surround from my tv. Have studied the 80 odd page manual, but just can't seem to grasp what i'm doing wrong. Any help/advice would be enormously appreciated. Many thanks.
  2. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Anyone?
  3. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Has no-one set one of these up then? Would like to know what other people have set there beam and sound settings up at for a room 15 x 12. Desperate for advice.
  4. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Come on, someone must have set one of these up. Getting desperate now.
  5. Wilson D
    Wilson D
    Nov 21, 2016
    407
    Newcastle upon Tyne
    +71
    Im lookin at buying one of these, asked if anyone had one never got a single reply.
  6. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    If nobody can advise me soon, I could be selling mine.
  7. Wilson D
    Wilson D
    Nov 21, 2016
    407
    Newcastle upon Tyne
    +71
    Is it really that bad?
  8. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    80 pages of manual and set up that I can't quite take in. Should have stuck to my Bose set up, lol.
  9. Wilson D
    Wilson D
    Nov 21, 2016
    407
    Newcastle upon Tyne
    +71
    Been lookin at this or the samsung k950 or just stick with the amp and speaker route.
  10. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Had no pointers off of here at all as to what is the best way to set this up and I can't seem to find an owners thread anywhere, only reviews. :(
  11. Wilson D
    Wilson D
    Nov 21, 2016
    407
    Newcastle upon Tyne
    +71
    Yeah looks like no one owns one. Not sure why as the reviews for it are really good.
  12. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Anyone?
  13. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,523
    +531
    I have the older YSP4100 and the auto setup generally does a good job. However, it can sometimes need tweaking if you have an odd shaped room, or lots of furniture, for example. In my case, I had to manually raise the centre channel level in the settings as vocals weren't as clear as I like, although my hearing isn't what it used to be.
    One thing that you haven't mentioned is the source components connected to the bar. If your ancillary kit isn't configured correctly then no end of tweaking the settings will make any difference.
    More details required.
    Clem
  14. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    I have sky q, samsung 4k player and slim ps4 all connected to the bar, then in to tv. Pretty sure these are configured ok. Yes the room is an l shape and the bar is below the height of the sideboard next to it. I have just bought the wall bracket for it, so I can raise the bar above it, then I will have to see if that has an effect. I also have my centre channel on +3 for dialog as the bar sits 3ft below wall mounted Tv. Maybe that is the problem.
  15. pol2711
    pol2711
    Mar 10, 2018
    3
    Wijk bij Duurstde
    hi all,
    been reading all above but I have sort of the same problem
    My HDMI1 on my YSP5600 is nog working. Tried different cables and devices but nothing.
    Also my ARC will not do what I want. A new cable between my YSP5600 (ARC out HDMI 4) into my Samsung ARC IN HDMI is not passing the audio from my TV to my soundbard. Sound comes out of my TV (what I do not want) and will nog come out of my YSP5600. Also here tried a brand new hi-res cable. Have I a deffective YSP5600?
    Thanks for any reply
  16. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,523
    +531
    Sounds like it. However, make sure that you have the latest firmware installed, then do a factory reset. Note that it you've been plugging-in/removing HDMI cables with equipment powered-up you may have damaged the HDMI port.
    Clem
  17. JayCee
    JayCee
    Jan 20, 2004
    23,367
    Lanarkshire
    +2,514
    And look at/change the TV's audio settings to output via ARC
  18. pol2711
    pol2711
    Mar 10, 2018
    3
    Wijk bij Duurstde
    OK thnx. Will do a factory reset. My TV only shows TV loudspeaker, Optical out and Bluetooth. No further options in the soundmenu
  19. JayCee
    JayCee
    Jan 20, 2004
    23,367
    Lanarkshire
    +2,514
    What's the TV's model no?
  20. pol2711
    pol2711
    Mar 10, 2018
    3
    Wijk bij Duurstde
    Samsung UE49KS7000. It worked, now not anymore. I did a full factory reset, it didn't did the trick. Usermanual is horrible. Advanced setting -> initialize -> info....and then what? But it did a full reset. Same problems however. I didn't know that changing HDMI the connected device should be off......
  21. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,523
    +531
    I think that you've damaged either the HDMI port on the TV or on the 5600, or possibly both. The only way to prove that is by substituting one of the devices then re-trying the connections/setup. Do you have another TV that you could try, for example?
    The rule with HDMI connections is at a minimum, the source device should not be powered when making or re-making connections, but ideally both devices should be unpowered. Wait a good couple of minutes after powering-down kit before removing or making connections.
    I've followed the source device unpowered connection method ever since HDMI surfaced, and thus far (touch wood) it hasn't let me down.
    I think that you have some expensive repairs on the way, unless you have a warranty to fall back on. First, however, you need to identify which device is at fault.
    Clem
  22. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Have now installed wall mount and fitted sound bar, I have also now connected everything into TV, then HDMI from ARC to soundbar. Do I also need to attach the optical from TV to sound bar?
    Even with altering the angle of the beam (horizontal/vertical) and the level of the channels, I must say that I am not really impressed, considering the cost of it. Truly disappointed, must be doing something wrong.
  23. Bulldognz
    Bulldognz
    Oct 18, 2017
    2
    4
    Auckland, NZ
    OK all, I have this sound bar and it's working great including sending audio back via ARC. For ARC to work you need the HDMI cable coming from the TV plugged into HDMI 4 (ARC) on settings menu you need hdmi control turned to on. and the TV input set to coaxial [AUX2], input HDMI1 should be selected on the sound bar to listen to the ARC channel
  24. dennis1
    dennis1
    Jan 31, 2008
    600
    gloucestershire
    +19
    Mine is connected the same way, TV arc to sound bar arc. When I turn sound bar on, it illuminates TV-ARC, which I assume is right. What I don't get is the other settings you mention, why would I select HDMI 1 if it already recognises the connection?
  25. Bulldognz
    Bulldognz
    Oct 18, 2017
    2
    4
    Auckland, NZ
    Apologies select the TV input on your remote. I read that wrong because if you press the info button to tell you the input it says HDMI 1!
  26. achild
    achild
    Jul 14, 2006
    47
    All - how’s does one do a factory reset - the manual is a little vague...
