Help with xlobby and power dvd
Discussion in 'Desktop & Laptop Computers Forum' started by schillaci0, Mar 4, 2005.
  1. schillaci0
    schillaci0
    Jan 18, 2005
    695
    Starting to get where I want to be
    +14
    When i click on the dvd images in xlobby to play, power dvd starts up but does not play straight away, have to then press play and then it takes me to playlists/edit/load etc and i cannot work it out :confused: . Probably very simple :lesson: but have now got brain drain :suicide: HELP.
  2. schillaci0
    schillaci0
    Jan 18, 2005
    695
    +14
    Anyone :lease:
  3. Werner
    Werner
    it sounds like you have powerdvd set to "file " mode instead of "dvd" mode. Because powerdvd can also play svcd's and vob files, it has a file mode to allow you to set individual files.
    I'm not sure which graphic on the interface does it (it's difficult to describe things like hammer, saw, squiggly line) but if you hover over them a tooltip will pop up, look for the one labelled file mode and click it to set it to dvd mode.
    Hope this helps
  4. schillaci0
    schillaci0
    Jan 18, 2005
    695
    +14
    looked in power dvd and cannot find the modes you mention do you know where they are werner
    Thanks in advance.
