Help with xbox live
Soulja
AVF TT Runner Up 06
i've borrowed a friend my netgear dg632 and hes managed to connect to the internet and xbox live but we can't private chat, join each others games or anything but other people can join his games and chat to him, is it anything to do with my old ip or something being on the modem?
C225
are the NAT open on both of the connections?
Soulja
AVF TT Runner Up 06
my nat is 'strict' how do i open it? i'll check my friends later
Firstly upgrade the firmware and then follow Shadowmans guide...I bet just turing on uPnP will fix it.
Remember your mate have to do similiar on his setup as you both need "open" NAT connections.
ShadowmanUK
Soulja said:
upnp is turned on:(
Get the latest firmware for the router. If after that you still get strict with UPnP on, turn it off and put your Xbox in a DMZ (instructions on how to do this are on my website)
Soulja
AVF TT Runner Up 06
i checked speedtouchs website but there isn't any for my speedtouch 576
Soulja
AVF TT Runner Up 06
ye, my friends is netgear his nat is moderate, i checked mine and its strict so i'm guessing mine is the problem :(
ShadowmanUK
I give good recommendations on my website. Tho the ones you and your friend have are fine. They just need fine tuning thats all
Similar threads
Trending threads
